NDI
ProPresenter 6 to vMix via NDI and chroma key issues
Joined: 4/19/2014(UTC) Posts: 64  Location: United States Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
Hello vMix family. I'm not sure if this should be in the general discussion or NDI so please let me know if it's misplaced.
I am capturing our church slides being driven in ProPresenter 6 via Desktop Capture / NDI. In ProPresenter I am making the background green so that I can key the background out in vMix and use the text in a different production.
The issue I and having is the inability to pull a clean key. The edges of the text always look rough and pixelated after the key. I have tried several different green color backgrounds, blue and even black.
Is this a result due to the lack of data from the NDI feed or is this just a limitation of the keyer in vMix. In practical lighting situations, I find most bad keying can be solved by lighting the green screen evenly but in this situation we have a perfect green color and contrasting text. Lighting is not a factor.
Thanks in advance for any tips or ideas.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
Hi Nick
I don't use pro presenter, but I see it supports alpha keying (at least with an option module).
Can't you design your titles with alpha transparent backgrounds that NDI supports natively? It would be a perfect solution if it's possible.
Regarding your issue, I never had excellent results with green keying on texts either.
DWAM wrote:Hi Nick
Regarding your issue, I never had excellent results with green keying on texts either. The add on module is rather expensive. They also have and NDI / SDI module but at a cost. I like ProPresenter but they nickel and dime you with all these add on modules. With the power of vMix, NDI and Desktop I was hoping to solve the issue without any additional software add-ons and cost.
NDI
