jhill0224
#1 Posted : Sunday, February 5, 2017 1:40:34 PM(UTC)
jhill0224
Does anyone have insight in how to do this? I have a .mov lower thirds motion file that I would like to convert to use in vmix. I see that this is possible through illustrator. I only have photoshop and premier pro though.
Any suggestions welcome.
#2 Posted : Sunday, February 5, 2017 1:59:40 PM(UTC)
Hi
You need to export your .mov into an image sequence. Adobe Media Encoder can do it. But it won't be easy to use it in a xaml title anyway.
You can also use MS Expression Blend to produce animated xaml
OR
do a multiview which associates your .mov lowerthirds and a text field only xaml file
#3 Posted : Sunday, February 5, 2017 2:55:42 PM(UTC)
OR use the vMix videotools to "create an image sequence from a source file containing alpha channel"
then load as image sequence input and use as animated title with loop if so desired
