.mov (or other extension) to .xaml conversion
Joined: 11/2/2016(UTC) Posts: 17 Location: Houston, TX
Does anyone have insight in how to do this? I have a .mov lower thirds motion file that I would like to convert to use in vmix. I see that this is possible through illustrator. I only have photoshop and premier pro though.
Any suggestions welcome.
Hi
You need to export your .mov into an image sequence. Adobe Media Encoder can do it. But it won't be easy to use it in a xaml title anyway.
You can also use MS Expression Blend to produce animated xaml
OR
do a multiview which associates your .mov lowerthirds and a text field only xaml file
OR use the vMix videotools to "create an image sequence from a source file containing alpha channel"
then load as image sequence input and use as animated title with loop if so desired
