anddunn
#1 Posted : Monday, April 29, 2013 3:57:09 PM(UTC)
anddunn
Hi, all the colour keying options are greyed out and the key colour for the remote desktop does not work, can you help.
Andrew
Egriswold
#2 Posted : Tuesday, April 30, 2013 3:03:44 PM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
You need to check the "Color Key" box first
anddunn
#3 Posted : Tuesday, April 30, 2013 5:22:09 PM(UTC)
anddunn
Hi, the "colour key" box is greyed out as well will not tick,
Andrew
Egriswold
#4 Posted : Tuesday, April 30, 2013 5:39:08 PM(UTC)
Egriswold
What version of VMix are you using ?
Also what module are you trying to key with? Do all modules show the Chroma key grayed out no matter the type of module?
anddunn
#5 Posted : Tuesday, April 30, 2013 6:02:24 PM(UTC)
anddunn
Hi, SD Basic 9.1.0.31, I have uninstalled it and reinstalled still the same, not one module will allow keying. Looking to get SD or HD if I can get keying working, need more than 1 overlay.
#6 Posted : Tuesday, April 30, 2013 8:12:37 PM(UTC)
Hi Andrew,
If the chroma key is greyed out it means you have an old graphics card that does not support this ability.
I would suggest upgrading your graphics card to get it working.
Similar Topics
Improved Chroma Keying in VMix 22 (Feature Requests)
by waynew 5/1/2018 11:06:26 AM(UTC)
Video Jerkiness in vMix on Chroma Keying (General Discussion)
by carlosowusu 7/10/2013 4:44:57 AM(UTC)
Better chroma keying = adjustable Choke & Soften (Feature Requests)
by jet 6/17/2013 12:52:05 PM(UTC)
Chroma keying (General Discussion)
by THPI 6/14/2013 8:15:21 PM(UTC)
Chroma Keying doubt. (General Discussion)
by fabio_ps 1/27/2011 3:15:30 PM(UTC)
