Hi, all the colour keying options are greyed out and the key colour for the remote desktop does not work, can you help.
Andrew
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
You need to check the "Color Key" box first
Hi, the "colour key" box is greyed out as well will not tick, Andrew
What version of VMix are you using ? Also what module are you trying to key with? Do all modules show the Chroma key grayed out no matter the type of module?
Hi, SD Basic 9.1.0.31, I have uninstalled it and reinstalled still the same, not one module will allow keying. Looking to get SD or HD if I can get keying working, need more than 1 overlay.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Hi Andrew,
If the chroma key is greyed out it means you have an old graphics card that does not support this ability. I would suggest upgrading your graphics card to get it working.
Martin vMix
