jmorgan196
#1 Posted : Wednesday, April 10, 2013 3:41:48 PM(UTC)
jmorgan196
Initially, the video from the camera shows great. But, then after several minutes, the video skips or it maybe dropping frames.
The camera is connected to a laptop (Dell M6600 via Firewire connection) for capturing the video.
I am not sure of what the real issue is nor how to resolve it at this point.
Any help would be greatly appreciated.
Thanks,
Johnny
#2 Posted : Thursday, April 11, 2013 10:35:33 AM(UTC)
Hi Johnny,
Could you explain a bit more detail how the camera is connected to your laptop?
The Canon XA10 does not support Firewire as a connection method so I assume you have some kind of converter box?
jmorgan196
#3 Posted : Thursday, April 11, 2013 2:31:32 PM(UTC)
jmorgan196
I may have gotten the name wrong for the connection. Below is the instructions from the camera's manual that describe the connection from the camera to the laptop.
Connecting to a Computer
To connect the camcorder to a computer you will need a computer equipped with an IEEE1394(DV) terminal
and video editing software with video capturing capability installed. Use the optional CV-250F (4 pin-6pin)
DV cable or a commercially available 6 pin-6 pin DV cable.
Thanks for responding,
Johnny
#4 Posted : Friday, April 12, 2013 10:37:07 AM(UTC)
Can you double check the model number on your camera?
The Canon XA10 does not have a firewire connection.
jmorgan196
#5 Posted : Saturday, April 13, 2013 12:38:21 AM(UTC)
jmorgan196
The model is XH A1S
