kubsix
#1 Posted : Friday, February 3, 2017 10:17:47 PM(UTC)
kubsix
When recording in mp4 format would you expect both resolution and bit rate to affect the files size?
I'm not seeing any change when changing resolution but I do when changing bit rate.
Guess I thought I read somewhere that file size is related to (resolution W x resolution H x bit rate). Any truth to that?
#2 Posted : Saturday, February 4, 2017 3:47:58 AM(UTC)
MP4: would you expect both resolution and bit rate to affect the files size?
No
Not with compression
A 1000x1000 pixels white image file in jpg will be smaller in weight than a 10x10 photo.
kubsix on 2/4/2017(UTC)
zenvideo
#3 Posted : Saturday, February 4, 2017 4:22:37 AM(UTC)
zenvideo
File size = Bit-rate x duration
If you think about it, the file size is measured in bits or bytes (where 8bits = 1 byte), or in KB or MB, and the bit-rate is bits per second, so what you're defining is effectively size/time, and duration equals time, so the overall formula is "size/time x time = size".
Resolution doesn't come into this particular equation, but there is a bigger equation in which you could include it, along the lines of:-
"resolution x frame rate x quality = bit-rate" so that if you want to increase the resolution or frame rate AND maintain the quality (using the same codec), then you must also increase the bit-rate, and by implication also the file size (for a given duration).
thanks 2 users thanked zenvideo for this useful post.
stigaard on 2/4/2017(UTC), kubsix on 2/4/2017(UTC)
