mp4 File size ...re: resolution and bit rate
When recording in mp4 format would you expect both resolution and bit rate to affect the files size?
I'm not seeing any change when changing resolution but I do when changing bit rate.
Guess I thought I read somewhere that file size is related to (resolution W x resolution H x bit rate). Any truth to that?
Quote:MP4: would you expect both resolution and bit rate to affect the files size? No Quote:file size is related to (resolution W x resolution H x bit rate). Not with compression A 1000x1000 pixels white image file in jpg will be smaller in weight than a 10x10 photo.
kubsix wrote:When recording in mp4 format would you expect both resolution and bit rate to affect the files size?
Guess I thought I read somewhere that file size is related to (resolution W x resolution H x bit rate). Any truth to that? File size = Bit-rate x duration If you think about it, the file size is measured in bits or bytes (where 8bits = 1 byte), or in KB or MB, and the bit-rate is bits per second, so what you're defining is effectively size/time, and duration equals time, so the overall formula is "size/time x time = size". Resolution doesn't come into this particular equation, but there is a bigger equation in which you could include it, along the lines of:- "resolution x frame rate x quality = bit-rate" so that if you want to increase the resolution or frame rate AND maintain the quality (using the same codec), then you must also increase the bit-rate, and by implication also the file size (for a given duration).
 2 users thanked zenvideo for this useful post.
