NDI
OSX NDI for Adobe Creative Cloud released
2 users thanked kane for this useful post.
DWAM on 1/31/2017(UTC), SHMD on 2/2/2017(UTC)
Joined: 10/1/2016(UTC) Posts: 117 Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
Yah! Was waiting for this...
SHMD wrote:Yah! Was waiting for this...
Download on our mac pro and can't seem to select ndi as an output in Adobe premier Pro and After Effects 2017. No option shows up for ndi? Running OSX 10.11.6 (El Capitan) -sheldon
I don't think the After Effect plug-in is in this release for OSX. I have it working on Premiere on my MacBook Pro with OSX 10.12 (I wish I go to back to 10.11!) As far as I'm aware it doesn't require OSX 10.12 to operate, but I've only got the one Mac to test it on. There are settings you need to select so that Premiere sends it video and audio output to NDI, have you set that in Premiere?
Kane Peterson NewTek
1 user thanked kane for this useful post.
OK, will check on Premier again as I am just updating it to the latest version from CC...
I will report back, once I see if it shows up in the display and audio section... I may have missed it as I spent most the time trying to get it to work in After Effects ;)
-sheldon
Hello Kane, I can confirm it is working with Adobe Premier Pro CC 2017 on OSX 10.11.6. It does not show up as a output in After Effects CC 2017, but you mentioned it was not supported yet. I made a screen shot of the output settings for Premier so vmix users have a reference that are on Mac. -s SHMD attached the following image(s): NDI.png (74kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
The NDI plugin for After Effects does not show up as a Mercury Playback Plugin. It is always active and will start to show video after you scrub the first frame.
1 user thanked zcondren for this useful post.
NDI
