kane
#1 Posted : Tuesday, January 31, 2017 7:03:02 PM(UTC)
kane
OSX NDI for Adobe Creative Cloud released!
http://newtek.com/ndi/tools#download-tools
Kane Peterson
NewTek
thanks 2 users thanked kane for this useful post.
DWAM on 1/31/2017(UTC), SHMD on 2/2/2017(UTC)
SHMD
#2 Posted : Thursday, February 2, 2017 9:28:13 AM(UTC)
SHMD
Canada
Was thanked: 52 time(s) in 31 post(s)
Yah! Was waiting for this...
SHMD
#3 Posted : Thursday, February 2, 2017 2:13:08 PM(UTC)
SHMD
Canada
Download on our mac pro and can't seem to select ndi as an output in Adobe premier Pro and After Effects 2017. No option shows up for ndi?
Running OSX 10.11.6 (El Capitan)
-sheldon
kane
#4 Posted : Thursday, February 2, 2017 5:35:36 PM(UTC)
kane
I don't think the After Effect plug-in is in this release for OSX. I have it working on Premiere on my MacBook Pro with OSX 10.12 (I wish I go to back to 10.11!) As far as I'm aware it doesn't require OSX 10.12 to operate, but I've only got the one Mac to test it on. There are settings you need to select so that Premiere sends it video and audio output to NDI, have you set that in Premiere?
Kane Peterson
NewTek
thanks 1 user thanked kane for this useful post.
SHMD
#5 Posted : Thursday, February 2, 2017 6:29:36 PM(UTC)
SHMD
Canada
OK, will check on Premier again as I am just updating it to the latest version from CC...
I will report back, once I see if it shows up in the display and audio section... I may have missed it as I spent most the time trying to get it to work in After Effects ;)
-sheldon
SHMD
#6 Posted : Thursday, February 2, 2017 7:47:46 PM(UTC)
SHMD
Canada
Hello Kane,
I can confirm it is working with Adobe Premier Pro CC 2017 on OSX 10.11.6.
It does not show up as a output in After Effects CC 2017, but you mentioned it was not supported yet.
I made a screen shot of the output settings for Premier so vmix users have a reference that are on Mac.
-s
SHMD attached the following image(s):
zcondren
#7 Posted : Saturday, February 11, 2017 1:56:35 PM(UTC)
zcondren
The NDI plugin for After Effects does not show up as a Mercury Playback Plugin. It is always active and will start to show video after you scrub the first frame.
thanks 1 user thanked zcondren for this useful post.
SHMD on 2/11/2017(UTC)
