mochaumedia
#1 Posted : Tuesday, January 31, 2017 9:42:32 AM(UTC)
mochaumedia
Was thanked: 3 time(s) in 1 post(s)
anyone know anything about midi settings with Roland V1-HD? Can it work with Vmix? Only have used it with Magewell hdmi to usb3, and it works perfect. But want to know if anyone have tryed it with midi settings?
Link to Roland V-1HD
PDF for Midi settings
mochaumedia attached the following image(s):
#2 Posted : Tuesday, January 31, 2017 10:55:22 AM(UTC)
Hi!
I quite don't understand what you're expecting from this?
This device and vMix are concurrent: they both are video switchers.
If your idea is to use Roland as a control device for vMix, it's quite strange.
It can be used as pre-switcher for HDMI inputs for sure with vMix doing everything else (rec/stream/graphics/etc) but I really don't see why this would be related to Roland midi settings...
Guillaume
mochaumedia
#3 Posted : Tuesday, January 31, 2017 11:39:10 AM(UTC)
mochaumedia
Use it like X-keys, perhaps X-key is better for use as control device for switch angles?
DWAM wrote:
Hi!
Guillaume
#4 Posted : Tuesday, January 31, 2017 11:54:37 AM(UTC)
Ok this is what I had understood, hence my surprise...
Now what device would you connect your cameras to? This one or vMix PC ?
SportsNetUSA.net
#5 Posted : Tuesday, January 31, 2017 12:25:29 PM(UTC)
SportsNetUSA.net
Mostly, you would use the MIDI to control the Roland V-1HD remotely, but it does allow for MIDI output by setting MIDI OUT to out. So if you have the V-1HD presently, put it on that setting and then see if you can setup Shortcuts in vMix using the find key option.
If you haven't purchased the Roland, an X-keys would be a much better control option for vMix. If you want to use the Roland V-1HD for camera switching and vMix for everything else that should work. However the use of MIDI OUT from the Roland to vMix probably would have very limited functionality using them together.
thanks 1 user thanked SportsNetUSA.net for this useful post.
mochaumedia on 1/31/2017(UTC)
mochaumedia
#6 Posted : Tuesday, January 31, 2017 4:00:44 PM(UTC)
mochaumedia
Hi, I would look for X-keys then. I have watched some videos on Youtube and it looks it's very easy to setup.
Thanks for great answer.
#7 Posted : Tuesday, January 31, 2017 5:38:58 PM(UTC)
If you connect your cams to Roland and add X-Keys for vMix, in the end, you have 2 control devices + a keyboard...
Maybe you can simply switch cams on Roland and use your keyboard (for some shortcuts if you really need shortcuts) or simply your mouse to control vMix...
Similar Topics
Computer To Run vMix And A Roland V-1HD (General Discussion)
by danspada 11/18/2017 10:09:28 PM(UTC)
