JohnRichter
#1 Posted : Monday, January 30, 2017 4:19:52 PM(UTC)
JohnRichter
TL/DR:
When using a local desktop capture as an input, how do I add an audio source that will be automatically used each time the desktop input is selected?
The details:
- vMix (18.0.0.61)
- Windows 10 PC
- Apollo Twin external USB audio capture device
- Magewell external USB video capture device
- PowerPoint 2010
I have setup input #1 for my camera & external mic - and they both work perfectly.
I have setup a desktop capture (input #2) to view PowerPoint slides.
The slides show up fine, however, I can't seem to find a way to add my mic input to the desktop capture, and there is no audio meter in the Audio Mixer for the desktop.
Once the Desktop Input #2 is selected, I can goto the Audio Mixer and click the speaker button for my camera (input #1) and the sound will mix into the desktop.
However, as soon as I switch inputs and then return to the desktop, the speaker button is no longer selected. I can click it again, but this is not helping the flow of my delivery on my webinar.
Any ideas?
Thank you in advance!
John
JohnRichter attached the following image(s):
vMix-Audio & Desktop.png (107kb) downloaded 6 time(s).
SportsNetUSA.net
#2 Posted : Monday, January 30, 2017 5:21:00 PM(UTC)
SportsNetUSA.net
Why not add your Apollo audio device as a separate input? It will always be on unless you turn it off.
IceStream talks about having your audio always on for a camera source in this thread
http://forums.vmix.com/default.aspx?g=posts&t=8776
You could also do it with a Shortcut that switches to input 2/Desktop capture and turns the "camera" audio on. That's not the best way but it works.
thanks 2 users thanked SportsNetUSA.net for this useful post.
JohnRichter on 1/30/2017(UTC), jhill0224 on 2/5/2017(UTC)
JohnRichter
#3 Posted : Monday, January 30, 2017 10:15:50 PM(UTC)
JohnRichter
Hey SportsNet-
Your solution worked perfectly. Thank you!
