Thanks: 1 times Was thanked: 9 time(s) in 6 post(s)
Try downloading the free trial, and please report back your findings. It's possible that those that are active on this board dont't own a DCX950.
This camera could work, without question. But the real question is: what interface or capture-card are you going to use? The capture card is the link between your camera and vMix. You will need a card that supports your camera and is supported by vMix.
I´will try it and post the results. Thanks
