mbmaciel
#1 Posted : Friday, March 29, 2013 5:32:40 PM(UTC)
mbmaciel
I have 2 cameras sony DXC950 RGB. Description on link: http://www.broadcaststor.../model/17991/v-10575.pdf
Does it work with vmix ?
jwolthuis
#2 Posted : Friday, March 29, 2013 8:31:48 PM(UTC)
jwolthuis
Was thanked: 9 time(s) in 6 post(s)
Try downloading the free trial, and please report back your findings. It's possible that those that are active on this board dont't own a DCX950.
macjaeger
#3 Posted : Friday, March 29, 2013 9:11:36 PM(UTC)
macjaeger
This camera could work, without question. But the real question is: what interface or capture-card are you going to use? The capture card is the link between your camera and vMix. You will need a card that supports your camera and is supported by vMix.
mbmaciel
#4 Posted : Sunday, March 31, 2013 8:53:55 AM(UTC)
mbmaciel
I´will try it and post the results. Thanks
