Sound cutting few seconds every few minutes
we are running Vmix on a:
i7 6800k GTX1070 Windows 10 16 Go RAM Sound we tried Rolad Quad, Focuriste 6i6 Blackmagic Quad 2 Vmix 4K pro
The PC has no other application except chrome and the blackmagic program installed
Our lives are in 1080 59.94p
We are experiencing few 1 to 2 seconds silences every few minutes, every thing is random (duration of silence, recuring time etc..) On the windows record panel the sound still appear, but on VMix it keeps cutting down. Changing the sound capture card doesn't change the fact we are getting thoses silences.
It not a lag of the system, wich runs fine during the cuts.
Any idea?
Regards
Thanks: 45 times Was thanked: 3 time(s) in 3 post(s)
What motherboard and chipset?
Mother Board: X99A XPOWER GAMING TITANIUM (MS-7A21)
Chipset: North Intel Broadwell-E 01 South Intel X99 05
the capture card is in PCI and the sound card is in USB
Salut presque Voisin There are many issues with audio with X99 motherboards. You can check this topic for more information directly from Martin Sinclair regarding the use of these motherboards with vMix but also more generally the issues encountered by audio professionals. http://forums.vmix.com/d....aspx?g=posts&t=8456At the moment, it is recomended to avoid X99 chipset but you might find useful tips or settings that might work for you A+ Guillaume
