I have a AKAI APC mini for my cuts, graphics and audio features and also use a x-keys xk-12 for my PTZ Optics camera. the issue i am having is the mini and the xkeys keep getting the same channel and note on certain keys. This is extremely irritating as my x-keys are my camera presets and my mini is everything else and when i take and hit keys that are the same it throws off the other controller.
my question is their a way to fix this issue or change the channel of the x-keys or apc mini so when you "find" the shortcut key i will not interfere with the other controllers keys?
Hi Scotty
It is not possible to change the default midi channel the Akai APC Mini uses, it's fixed to 1. I don't know if it's possible for XKeys, you gotta check that.
Guillaume
