scottyp
#1 Posted : Monday, January 16, 2017 8:27:29 PM(UTC)
scottyp
I have a AKAI APC mini for my cuts, graphics and audio features and also use a x-keys xk-12 for my PTZ Optics camera. the issue i am having is the mini and the xkeys keep getting the same channel and note on certain keys. This is extremely irritating as my x-keys are my camera presets and my mini is everything else and when i take and hit keys that are the same it throws off the other controller.
my question is their a way to fix this issue or change the channel of the x-keys or apc mini so when you "find" the shortcut key i will not interfere with the other controllers keys?
#2 Posted : Tuesday, April 4, 2017 6:35:07 AM(UTC)
Hi Scotty
It is not possible to change the default midi channel the Akai APC Mini uses, it's fixed to 1.
I don't know if it's possible for XKeys, you gotta check that.
Guillaume
Similar Topics
Using Xkeys XK-12 Jog & Shuttle to Rewind video (3rd Party Software and Development)
by tomthinks 5/3/2019 10:16:44 AM(UTC)
Xkeys XK-12 joystick support (Hardware Compatibility)
by Mathijs 9/2/2016 2:22:07 PM(UTC)
