kjones9999
#1 Posted: : Monday, January 16, 2017 9:02:00 AM(UTC)
kjones9999
Here's the issue -
NDI looks great on my i5 with 8 gb ram and an integrated GPU.
On my i7 laptop with Nvidia GPU 8 GB, its choppy. VERY choppy.
CPU is low... any ideas on how to troubleshoot?
#2 Posted : Monday, January 16, 2017 9:28:22 AM(UTC)
Was thanked: 4660 time(s) in 1606 post(s)
First thing I would check is to make sure the network connection on the i7 is actually connecting as gigabit.
The cable could be faulty for example, and NDI needs more than 100mbps for 1080p.
kjones9999
#3 Posted : Monday, January 16, 2017 10:15:31 AM(UTC)
kjones9999
Hi Martin.
Yes its confirmed by the control panel in win8. These are also going into the same switch.
thanks 1 user thanked kjones9999 for this useful post.
r@wisla on 1/24/2017(UTC)
#4 Posted : Monday, January 16, 2017 11:32:24 AM(UTC)
What does Task Manager report as the bandwidth received when the NDI feed is playing?
kjones9999
#5 Posted : Monday, January 23, 2017 10:46:32 PM(UTC)
kjones9999
Updating the Nvidia driver solved the issue.
stigaard
#6 Posted : Tuesday, January 24, 2017 6:07:09 AM(UTC)
stigaard
Denmark
Good to know that the NVidia graphics driver can cause problem, so it's important to keep the driver updated. Thanks for sharing your solution kjones9999.
