NDI
NDI Stutters on one Laptop, fine on the other
Here's the issue -
NDI looks great on my i5 with 8 gb ram and an integrated GPU.
On my i7 laptop with Nvidia GPU 8 GB, its choppy. VERY choppy.
CPU is low... any ideas on how to troubleshoot?
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
First thing I would check is to make sure the network connection on the i7 is actually connecting as gigabit. The cable could be faulty for example, and NDI needs more than 100mbps for 1080p.
Martin vMix
Hi Martin.
Yes its confirmed by the control panel in win8. These are also going into the same switch.
 1 user thanked kjones9999 for this useful post.
What does Task Manager report as the bandwidth received when the NDI feed is playing?
Updating the Nvidia driver solved the issue.
kjones9999 wrote:Updating the Nvidia driver solved the issue. Good to know that the NVidia graphics driver can cause problem, so it's important to keep the driver updated. Thanks for sharing your solution kjones9999.
NDI
