e.movie
#1 Posted : Sunday, January 15, 2017 6:01:25 AM(UTC)
e.movie
I tried to add more inputs but I get the error message "capture device are still in use". Whit a Matrox MXO2 card can i use only one input? where is possible to use multi input? thanks
Mathijs
#2 Posted : Sunday, January 15, 2017 8:05:53 AM(UTC)
Mathijs
I do not think it is a multi input device for same time usage.
In the description and manual they talk about selecting the input, they never say you can use more inputs at the same time..
e.movie
#3 Posted : Sunday, January 15, 2017 8:14:50 AM(UTC)
e.movie
Thanks for the reply
zenvideo
#4 Posted : Sunday, January 15, 2017 12:38:44 PM(UTC)
zenvideo
e.movie wrote:
With a Matrox MXO2 card can i use only one input? where is possible to use multi input? thanks
All the Matrox MX02 devices are single channel devices, even though you can select that single input from a selection of different external connections (which vary according to the different models in the range).
