I tried to add more inputs but I get the error message "capture device are still in use". Whit a Matrox MXO2 card can i use only one input? where is possible to use multi input? thanks
I do not think it is a multi input device for same time usage. In the description and manual they talk about selecting the input, they never say you can use more inputs at the same time..
e.movie wrote:With a Matrox MXO2 card can i use only one input? where is possible to use multi input? thanks All the Matrox MX02 devices are single channel devices, even though you can select that single input from a selection of different external connections (which vary according to the different models in the range).
