BigRev
#1 Posted : Saturday, January 14, 2017 5:01:01 PM(UTC)
BigRev
Rank:: Newbie
Not sure what I need to adjust.
Thanks.
#2 Posted : Saturday, January 14, 2017 5:13:23 PM(UTC)
What is your source ? A computer ? vMix will display the source maximized according to the aspect ratio. For example if your source is 1440x900 (16/10) this cannot be maximized to 1920x1080 (16/9). You will have transparent borders on each sides.
You can change the aspect ratio setting in your NDI input properties (set it to widescreen) but your image will be distorted.
