NDI
Using NDI...not appearing as full screen in vmix
Not sure what I need to adjust.
Thanks.
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
What is your source ? A computer ? vMix will display the source maximized according to the aspect ratio. For example if your source is 1440x900 (16/10) this cannot be maximized to 1920x1080 (16/9). You will have transparent borders on each sides.
You can change the aspect ratio setting in your NDI input properties (set it to widescreen) but your image will be distorted.
NDI
