kol0
#1 Posted : Thursday, December 22, 2016 6:32:37 PM(UTC)
kol0
Was thanked: 8 time(s) in 8 post(s)
Hi
It would be great if, countdown timer could cause interruption (Triggers).
If zero do something.
I've seen some request of scheduled events. With trigger could do this without adding additional code. It was enough to set a countdown that do not even have to be seen to made the cut, or add a channel overlay.
You could also use the timer as an automatic cut cameras.
It was enough to add to the playlist in the loop and in manual mode, the camera.
The timer had came to zero was setting to the next item in the playlist. addition, reset the counter, starting a new countdown.
thanks 1 user thanked kol0 for this useful post.
clafarge on 6/11/2017(UTC)
Amokka
#2 Posted : Thursday, December 22, 2016 6:46:15 PM(UTC)
Amokka
Was thanked: 18 time(s) in 13 post(s)
+1
#3 Posted : Thursday, December 22, 2016 8:31:42 PM(UTC)
+1
stigaard
#4 Posted : Friday, December 23, 2016 8:45:04 AM(UTC)
stigaard
Denmark
+1
Lennart
#5 Posted : Sunday, December 25, 2016 10:50:28 AM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
+1
Video Dave
#6 Posted : Sunday, December 25, 2016 1:21:52 PM(UTC)
Video Dave
+1
r@wisla
#7 Posted : Sunday, December 25, 2016 2:21:24 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
+1
If zero do sth
Or
If hour == xx do sth
curtismacd31
#8 Posted : Sunday, December 25, 2016 3:40:33 PM(UTC)
curtismacd31
+1
corporatejames
#9 Posted : Sunday, December 25, 2016 5:04:54 PM(UTC)
corporatejames
+1
kol0
#10 Posted : Friday, January 6, 2017 5:09:26 AM(UTC)
kol0
You can countdown to time
Countdown to 11:59:59
{0:11:59:59|HH:mm:ss}
Countdown to 16:30:00
{0:16:30:00|HH:mm:ss}
So you can achieve it just with "If zero do sth"
richardgatarski
#11 Posted : Monday, January 23, 2017 11:00:30 AM(UTC)
richardgatarski
+1
#12 Posted : Wednesday, January 25, 2017 10:26:45 AM(UTC)
+1
FYI, vMixUTC now supports 3 triggering options for timers/countdowns : OnStart, OnPause and OnStop. Really cool...
clafarge
#13 Posted : Thursday, June 1, 2017 10:11:00 PM(UTC)
clafarge
Was thanked: 20 time(s) in 13 post(s)
I'm looking for a way to do this too... at end of count to time, fade to Input12. Been messing with "OnCompletion" for the Timer overlay but no joy.
Chad
#14 Posted : Friday, June 2, 2017 4:03:41 AM(UTC)
Hi Chad
you need to
- first create a button widget which fades to input 12 (make sure it works by pressing the button)
- tick the "execute" box and fill the link area with a command name like "doit" or whatever
- then create your timer widget, set it correctly
- fill the OnCompletion area with the exact same command "doit"
Now, on completion, the timer sends the ExecLink command "doit" to your button.
Hope this helps
Guillaume
clafarge on 6/3/2017(UTC)
Ittaidv
#15 Posted : Friday, June 2, 2017 2:43:25 PM(UTC)
Ittaidv
+1 for having it in vmix!
madness
#16 Posted : Friday, June 2, 2017 4:08:56 PM(UTC)
madness
Views messages in topic : 406
+1
