Feature Requests
Triggers on end of countdown
Thanks: 5 times Was thanked: 8 time(s) in 8 post(s)
Hi
It would be great if, countdown timer could cause interruption (Triggers).
If zero do something.
I've seen some request of scheduled events. With trigger could do this without adding additional code. It was enough to set a countdown that do not even have to be seen to made the cut, or add a channel overlay.
You could also use the timer as an automatic cut cameras. It was enough to add to the playlist in the loop and in manual mode, the camera. The timer had came to zero was setting to the next item in the playlist. addition, reset the counter, starting a new countdown.
 1 user thanked kol0 for this useful post.
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Joined: 3/7/2012(UTC) Views messages in topic : 2,683  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
Joined: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, Denmark Thanks: 411 times Was thanked: 102 time(s) in 79 post(s)
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
Rank:: Advanced Member
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
+1
If zero do sth
Or
If hour == xx do sth
r@wisla wrote:If hour == xx do sth You can countdown to time Countdown to 11:59:59 {0:11:59:59|HH:mm:ss} Countdown to 16:30:00 {0:16:30:00|HH:mm:ss} So you can achieve it just with "If zero do sth"
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
+1
FYI, vMixUTC now supports 3 triggering options for timers/countdowns : OnStart, OnPause and OnStop. Really cool...
Joined: 5/27/2017(UTC) Posts: 93   Location: Greater St Louis Area Thanks: 67 times Was thanked: 20 time(s) in 13 post(s)
I'm looking for a way to do this too... at end of count to time, fade to Input12. Been messing with "OnCompletion" for the Timer overlay but no joy.
Chad
Hi Chad
you need to
- first create a button widget which fades to input 12 (make sure it works by pressing the button) - tick the "execute" box and fill the link area with a command name like "doit" or whatever
- then create your timer widget, set it correctly - fill the OnCompletion area with the exact same command "doit"
Now, on completion, the timer sends the ExecLink command "doit" to your button.
Hope this helps Guillaume
+1 for having it in vmix!
Feature Requests
