rowby
#1 Posted : Sunday, December 11, 2016 2:57:27 PM(UTC)
rowby
Hi
While using the undocked SlideShow settings to advance or jump from one slide to another, it's hard to see which slide is the active one. THere is a thin green line around the active slide. The green line looks about 1 or two pixels wide, and is surrounded by the black GUI.
Ideally the color should be selectable in overall Settings, or at least have a default color of yellow and 3 or 4 pixels wide. Then it can be much easier to see the currently selected slide.
Thanks!
Best,
Rowby
