	Feature Requests
	Thicker and more visible borders around active slideshow image Slideshow Settings
 Joined: 11/23/2016(UTC) Posts: 330  Location: USAThanks: 179 timesWas thanked: 26 time(s) in 25 post(s)
                Hi
 While using the undocked SlideShow settings to advance or jump from one slide to another, it's hard to see which slide is the active one.  THere is a thin green line around the active slide.  The green line looks about 1 or two pixels wide, and is surrounded by the black GUI.
 Ideally the color should be selectable in overall Settings, or at least have a default color of yellow and 3 or 4 pixels wide. Then it can be much easier to see the currently selected slide.
 Thanks!
 Best,
 Rowby
	Feature Requests
