mashynewie2
#1 Posted : Sunday, December 4, 2016 9:14:50 PM(UTC)
mashynewie2
Was thanked: 44 time(s) in 33 post(s)
A lot of graphics cards only have 2 H264 encoders.
If you run out of encoders when you hit the "Record" button it falls back to CPU encoding so everything continues on smoothly.
However, if I try running say 3 livestreams at once, I get a weird error.
Please allow live streams to automatically fallback to CPU encoding if all encoders on the GPU are in use.
Eg 1:
If I click RECORD then STREAM it will use hardware encoding for recording and for ONE of the live streams and for the remaining streams it falls back to CPU.
***OR***
Can 1 single encode process be used for multiple streams of the same bitrate/resolution?
thanks 1 user thanked mashynewie2 for this useful post.
niemi on 4/13/2017(UTC)
mashynewie2
#2 Posted : Sunday, February 19, 2017 8:59:53 AM(UTC)
mashynewie2
Someone else is having this issue here:
https://forums.vmix.com/...p;m=35390&#post35390
Just bumping this thread :)
It would be great if streaming or recording falls back to CPU encoding once the GPU encoders are all in use.
Thanks Martin!!
niemi
#3 Posted : Thursday, April 13, 2017 6:49:31 AM(UTC)
niemi
Was thanked: 18 time(s) in 15 post(s)
***OR***
Any news on this?
When streaming to multiple CDN's using the same encoding profile, do vMix really need to encode the same bits to the same bits several times?
mmorlan62
#4 Posted : Saturday, April 22, 2017 6:02:28 PM(UTC)
mmorlan62
Was thanked: 7 time(s) in 5 post(s)
I wonder if the frame tearing I encounter with GPU-encoded recordings has something to do with this. Once I switch to CPU, the artifacts go away.
