timothychew
#1 Posted : Wednesday, February 13, 2013 5:08:23 AM(UTC)
timothychew
Dear All
I am setting up a new system with asus PXP79
I manage to get intensity x 2 to work
but My intensity shuttle cant work
I try media express to load ... it dont work also
they said need to use NEC usb ( so I try to buy a NEC PIC express )
but still the same Can anyone help
I am thinking of upgrade it to 4 intensity pro ( input Full HD )
Using a HDMI extender for HDMI cam
ANy suggestion
h2video.nl
#2 Posted : Wednesday, February 13, 2013 5:48:28 AM(UTC)
h2video.nl
Hello Timo,
Getting the shutte to work can be a pain...
I have set it up now on my laptop USB3 after working on it for 6 months. It's about the chip and the latest drivers. I also have to output to hdmi in 1080p (not 1080i) in order to get everything smooth.
I also have a computer with two BM cards and sometimes I use the shuttle as well. This computer does not have a NEC, but it works. The problem with this computer was the power supply: I had to upgrade the power supply for the whole system to work.
So try the USB3 without the cards first. Then put one card in etc. If this is a fix, just upgrade the power.
Be sure to uninsall the drivers completely, then install again and only after that connect the shuttle. Use latest drivers. It's a step by step thing and I am a little disapointed with the BM cards' sensitivity to USB conncetions, but now they are working it's great.
PS I use a HP notebook DV7-6B60ED which has the NEC chip. I had a chance to buy exactly the same one last week (this thing is out of sale... a new version has INTEL chips ....) so I bought it as well, because I know it will work, I don't want to spend a new 6 months getting everything in line. I got it working in 1 day...
Good luck.
Stefan
timothychew
#3 Posted : Thursday, February 14, 2013 9:49:33 AM(UTC)
timothychew
thanks for your reply
I manage to detect the intensity shuttle
Thanks the Lord for helping
I reliase that not update driver will always good
I try to use the old driver and it fix my problem
but I think .. it is better to use NEC card
if u are using asus try to buy a cheap NEC card
and it will fix the problem
now I am using 2 intensity and 1 shuttle + 1 920 logitech
but logitech is slow can I improve the quality
is there any frame setting
timothychew
#4 Posted : Wednesday, March 6, 2013 7:01:08 PM(UTC)
timothychew
anyone setup these HDMI input with Cat5 extender
