Hardware Compatibility
New setup 2 intensity pro + 1 usb 3 intemsity shuttle
Dear All
I am setting up a new system with asus PXP79 I manage to get intensity x 2 to work
but My intensity shuttle cant work I try media express to load ... it dont work also
they said need to use NEC usb ( so I try to buy a NEC PIC express ) but still the same Can anyone help
I am thinking of upgrade it to 4 intensity pro ( input Full HD )
Using a HDMI extender for HDMI cam
ANy suggestion
Joined: 3/7/2012(UTC) Posts: 503  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
Hello Timo,
Getting the shutte to work can be a pain...
I have set it up now on my laptop USB3 after working on it for 6 months. It's about the chip and the latest drivers. I also have to output to hdmi in 1080p (not 1080i) in order to get everything smooth.
I also have a computer with two BM cards and sometimes I use the shuttle as well. This computer does not have a NEC, but it works. The problem with this computer was the power supply: I had to upgrade the power supply for the whole system to work.
So try the USB3 without the cards first. Then put one card in etc. If this is a fix, just upgrade the power.
Be sure to uninsall the drivers completely, then install again and only after that connect the shuttle. Use latest drivers. It's a step by step thing and I am a little disapointed with the BM cards' sensitivity to USB conncetions, but now they are working it's great.
PS I use a HP notebook DV7-6B60ED which has the NEC chip. I had a chance to buy exactly the same one last week (this thing is out of sale... a new version has INTEL chips ....) so I bought it as well, because I know it will work, I don't want to spend a new 6 months getting everything in line. I got it working in 1 day...
Good luck. Stefan
thanks for your reply I manage to detect the intensity shuttle Thanks the Lord for helping
I reliase that not update driver will always good I try to use the old driver and it fix my problem
but I think .. it is better to use NEC card if u are using asus try to buy a cheap NEC card
and it will fix the problem
now I am using 2 intensity and 1 shuttle + 1 920 logitech but logitech is slow can I improve the quality
is there any frame setting
anyone setup these HDMI input with Cat5 extender
