ask
#1 Posted : Sunday, November 6, 2016 11:17:56 PM(UTC)
ask
In testing the latest v18 build I noticed that the mpeg-ts files that I have previously created were not playing audio in vMix. In VLC all is fine. Other files (mp4, wav) are fine. I then tested in v17 and discovered the same behavior. This must have been around for a while but as I convert the .ts files to mp4 for upload in Handbrake I had not noticed the issue. Is this as per design?
Andrew
SportsNetUSA.net
#2 Posted: : Monday, November 7, 2016 5:03:25 PM(UTC)
SportsNetUSA.net
Playing back a MPEG-TS file in vMix 17.0.0.112 at this moment with audio. There must be another issue.
ask
#3 Posted : Monday, November 7, 2016 9:32:44 PM(UTC)
ask
Thanks for checking. Was this a file created by vMix? Have checked all I have created for the last few months. All have sound and can be played OK outside of vMix.
SportsNetUSA.net
#4 Posted : Monday, November 7, 2016 11:17:06 PM(UTC)
SportsNetUSA.net
Are you using Windows 7? If you are, then you will get no audio playing back in vMix 17. The laptop I was using has Windows 8.1 Pro. I just tested with my desktop that has Win 7 and vMix. There's no audio.
I believe Martin mentioned this when he was on Tom Sinclair's show.
ask
#5 Posted : Tuesday, November 8, 2016 1:21:03 AM(UTC)
ask
Nope, all Win 10AE. Have tried with the same files on a number of machines/vMix builds.
lbgaus
#6 Posted : Tuesday, November 8, 2016 8:04:31 PM(UTC)
lbgaus
To play back MPEG TS audio, you may need to install the AC3Filter. See: http://www.vmix.com/knowledgebase/article.aspx/14/no-audio-when-playing-certain-video-files-and-dvds
This fixed the issue for me a while back when I had this problem.
