	Shortcut "Disable Triggers"
  I'm new on this forum and with vmix, we bought Vmix 4k for a client.
  The camera / PTZ are triggered with audio detection.
  Is there any tips or shortcut to disable in a temporary way those triggers ? Is there a way to manually adjust the audio triggering (instead of 6/12/18 B) ?
  Thanks in advance for your help. Sorry for my english, I'm French.
 Joined: 8/12/2019(UTC) Posts: 10  Location: Houston TX Thanks: 20 times Was thanked: 3 time(s) in 2 post(s)
                I am also looking for some way to do this. If anyone knows how it can be done, I would be appreciative.
  As near as I can find for all my searching, this isn't possible.
  For my goals, just having a shortcut to disable/suppress triggers and then re-enable them later could save me nearly 20 inputs and a lot of overhead. I know I can work around it but it would be great if it was simple and efficient.
