p2m_
#1 Posted: : Thursday, October 20, 2016 12:43:22 PM(UTC)
p2m_
I'm new on this forum and with vmix, we bought Vmix 4k for a client.
The camera / PTZ are triggered with audio detection.
Is there any tips or shortcut to disable in a temporary way those triggers ?
Is there a way to manually adjust the audio triggering (instead of 6/12/18 B) ?
Thanks in advance for your help.
Sorry for my english, I'm French.
KnightHeart
#2 Posted : Thursday, July 16, 2020 6:38:07 AM(UTC)
KnightHeart
I am also looking for some way to do this. If anyone knows how it can be done, I would be appreciative.
As near as I can find for all my searching, this isn't possible.
For my goals, just having a shortcut to disable/suppress triggers and then re-enable them later could save me nearly 20 inputs and a lot of overhead. I know I can work around it but it would be great if it was simple and efficient.
