Hardware Compatibility
Mobile workstation (best CPU and GPU choices) for vMIx and capture card latency
admin wrote:
... For the lowest latency capture card I would recommend from lowest to highest latency: AJA, Magewell, Blackmagic
Regards, Martin vMix
http://forums.vmix.com/d....aspx?g=posts&t=5687Thanks Martin - love your work. 1) re capture latency how do YUAN High-Tech fare? (am about to order a SC510 N2) 2) would appreciate feedback regarding good choices for mobile CPUs and GPUs - i.e. i7 vs Xeon and GeForce vs Quadro We're considering the HP ZBook range - either HP ZBook 15 G3 (Intel Core i7 6820HQ | Quadro M2000M) vs HP ZBook 15 Studio G3 (Intel Xeon E3 1505MV5 | Quadro M1000M) Cheers, Luke p.s. idea: how about adding in a 'Card size' column to the 'Supported Hardware' table as half height / form factor can often be a requirement.
