Luke
#1 Posted : Tuesday, October 18, 2016 11:06:36 PM(UTC)
Luke
admin wrote:
For the lowest latency capture card I would recommend from lowest to highest latency: AJA, Magewell, Blackmagic
http://forums.vmix.com/d....aspx?g=posts&t=5687
Thanks Martin - love your work.
1) re capture latency how do YUAN High-Tech fare? (am about to order a SC510 N2)
2) would appreciate feedback regarding good choices for mobile CPUs and GPUs - i.e. i7 vs Xeon and GeForce vs Quadro
We're considering the HP ZBook range - either HP ZBook 15 G3 (Intel Core i7 6820HQ | Quadro M2000M) vs HP ZBook 15 Studio G3 (Intel Xeon E3 1505MV5 | Quadro M1000M)
Cheers,
Luke
p.s. idea: how about adding in a 'Card size' column to the 'Supported Hardware' table as half height / form factor can often be a requirement.
