 Thanks: 1 timesWas thanked: 5 time(s) in 3 post(s)
                hello ,
 please i need to send this request
 "http://127.0.0.1:8088/api/?Function=StartStreaming" without cout
 by adding a shortcut to vmix for midi device
 need this to control another vmix machine
 regards
 Thanks: 16 timesWas thanked: 82 time(s) in 72 post(s)
                Go to Settings - Scripting.Click Add.
 Paste this:
 Dim client = WebRequest.Create("http://127.0.0.1:8088/api/?Function=StartStreaming")
 Dim response = client.GetResponse()
 Of course change the 127.0.0.1 to the ip address of the other machine you want to control.
 Give your script a name at the top
 Click save
 Now go to Settings - Shortcuts
 Click Add
 Click Find
 Press the key on your midi device
 As Function, Click Scripting and select ScriptStart
 At Value, type the name you did give the script
 Click OK
 Done
              1 user thanked Mathijs for this useful post. |  |
