Thanks: 1 times Was thanked: 5 time(s) in 3 post(s)
hello ,
please i need to send this request "http://127.0.0.1:8088/api/?Function=StartStreaming" without cout
by adding a shortcut to vmix for midi device
need this to control another vmix machine
regards
Go to Settings - Scripting. Click Add. Paste this:
Dim client = WebRequest.Create("http://127.0.0.1:8088/api/?Function=StartStreaming") Dim response = client.GetResponse()
Of course change the 127.0.0.1 to the ip address of the other machine you want to control. Give your script a name at the top Click save
Now go to Settings - Shortcuts Click Add Click Find Press the key on your midi device As Function, Click Scripting and select ScriptStart At Value, type the name you did give the script Click OK
Done
 1 user thanked Mathijs for this useful post.
