vmix 17.0.0.111 problem external
Hi, I just installed the version 17.0.0.111 gives me this error:
StartStopExternal Unable to cast COM type 'System .__ objects ComObject' in interface types 'DecklinkPlugin.DeckLinkAPI.IDeckLinkOutput'. The operation was not completed because the QueryInterface call on the COM component for the interface with IID '{CC5C8A6E-3F2F-4B3A-87EA-FD78AF300564}' failed due to the following error: No such interface supported. (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
with previous versions was fine, unfortunately hd broke and I only recovered version 16 Vmix the most recent operating do not find them on the site.
my configuration: pc I7 3.0 ghz 16 gb ram hd 250 gb ssd only for windows system 10 nvidia gt 750 graphics card 2 gb blackmagic intensity pro Screen resolution 1920x1080
I found and installed the version 17.0.0.76 okay. why? thank you
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
You will need to update the blackmagic drivers as this error means they are over 2 years old!
Download new drivers, everything ok. Thank you
