op music
#1 Posted : Thursday, October 13, 2016 12:58:51 PM(UTC)
op music
Hi, I just installed the version 17.0.0.111 gives me this error:
StartStopExternal
Unable to cast COM type 'System .__ objects ComObject' in interface types 'DecklinkPlugin.DeckLinkAPI.IDeckLinkOutput'. The operation was not completed because the QueryInterface call on the COM component for the interface with IID '{CC5C8A6E-3F2F-4B3A-87EA-FD78AF300564}' failed due to the following error: No such interface supported. (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
with previous versions was fine, unfortunately hd broke and I only recovered version 16 Vmix the most recent operating do not find them on the site.
my configuration:
pc I7 3.0 ghz
16 gb ram
hd 250 gb ssd only for windows system 10
nvidia gt 750 graphics card 2 gb
blackmagic intensity pro
Screen resolution 1920x1080
I found and installed the version 17.0.0.76 okay.
why? thank you
#2 Posted : Thursday, October 13, 2016 10:27:23 PM(UTC)
You will need to update the blackmagic drivers as this error means they are over 2 years old!
op music
#3 Posted : Friday, October 14, 2016 6:03:56 AM(UTC)
op music
Download new drivers, everything ok. Thank you
