vince422
#1 Posted : Thursday, October 6, 2016 8:01:05 AM(UTC)
vince422
I want to know if it's possible to customize the Web controller interface with, for example, html files ?
If not, how is it possible to have status information of vMix with API? Indeed, I can send function to the API with requests like http://127.0.0.1:8088/api/?Function=Fade&Duration=1000 but I dont know how to have status of vMix information?
Thank you in advance. Cordially.
Vincent LEVEQUE
pm
#2 Posted : Thursday, October 6, 2016 8:51:18 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Hi Vincent
As I know there is no possibilty to customize the web controller interface.
For getting status information make a call to the url "http://127.0.0.1:8088/api" and you will get a XML file back with all the status information.
Patrick
vince422
#3 Posted : Friday, October 7, 2016 11:01:06 AM(UTC)
vince422
Indeed, I did not know this possibility that answers my problem.
Thank you.
Digitalson
#4 Posted : Tuesday, January 17, 2017 3:34:34 AM(UTC)
Digitalson
Groups: Guests
Can this tell me how some things are done via the web controller
phab
#5 Posted : Tuesday, January 17, 2017 8:41:27 AM(UTC)
phab
Perhaps this solution will work, Open Stage Control is a libre desktop OSC bi-directionnal control surface application. It's built with HTML.
http://osc.ammd.net/
exemples
http://openstagecontrol.herokuapp.com/
Best regard,
Phab
thanks 1 user thanked phab for this useful post.
PFBM on 1/18/2017(UTC)
MickeyMJJ
#6 Posted : Tuesday, November 26, 2019 7:06:21 AM(UTC)
MickeyMJJ
Would anyone have a configuration example to use OSC with vMix?
I can not find how to control the faders and they are bidirectional.
