Hello, I want to know if it's possible to customize the Web controller interface with, for example, html files ? If not, how is it possible to have status information of vMix with API? Indeed, I can send function to the API with requests like http://127.0.0.1:8088/api/?Function=Fade&Duration=1000 but I dont know how to have status of vMix information? Thank you in advance. Cordially. Vincent LEVEQUE
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Hi Vincent
As I know there is no possibilty to customize the web controller interface.
For getting status information make a call to the url "http://127.0.0.1:8088/api" and you will get a XML file back with all the status information.
Regards, Patrick
Indeed, I did not know this possibility that answers my problem.
Thank you.
Groups: Guests
Can this tell me how some things are done via the web controller
 1 user thanked phab for this useful post.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Hello, Would anyone have a configuration example to use OSC with vMix? I can not find how to control the faders and they are bidirectional.
