It would be fine to have a keystone option like in Arkaos Grandvj where you can set the 4 corners of the screen with your mouse. So you can set the projection size of the screen even if the projector is not correct mounted. rkeijsers attached the following image(s):  IMG_0121.PNG (58kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Of course it would be a great feature, but also a graphic heavy task for the PC to handle.
Can't you use a virtual input into something like resolume and do it there? We already used vmix together with resolume and it worked great!
