rkeijsers
#1 Posted : Thursday, September 29, 2016 1:17:32 AM(UTC)
rkeijsers
It would be fine to have a keystone option like in Arkaos Grandvj where you can set the 4 corners of the screen with your mouse.
So you can set the projection size of the screen even if the projector is not correct mounted.
rkeijsers attached the following image(s):
stigaard
#2 Posted : Thursday, September 29, 2016 5:57:11 AM(UTC)
stigaard
Denmark
Of course it would be a great feature, but also a graphic heavy task for the PC to handle.
Ittaidv
#3 Posted : Thursday, September 29, 2016 10:15:51 AM(UTC)
Ittaidv
Can't you use a virtual input into something like resolume and do it there? We already used vmix together with resolume and it worked great!
