Mathijs
#1 Posted : Friday, August 26, 2016 6:12:38 PM(UTC)
Mathijs
I use xkeys panels with vmix. My main system runs Windows 7 and however I connect the xkeys panels, it does recognize which is which, so my left panel is not getting mixed up with my right panel.
Now I have set up another system to show a client it can also be the perfect AV switcher with integrated playout.
This machine is running Windows 10.
Today I did take my keypanels with me of the main system, so I had two connected.
I did setup the shorcuts, checked that it all worked, and at a point I had to reboot the system.
After the reboot, my keypanels were mixed up and I had to pick up the "midi channels" again for each key to get it working like it should.
I will of course experiment more after I've run my job tommorrow. Did anyone else run into this and does know a solution?
desmar
#2 Posted : Saturday, August 27, 2016 9:37:39 AM(UTC)
desmar
Canada
1) Export shortcuts from your Windows 7 system with x-Keys attached.
2) Import shortcuts to your Windows 10 system with x-Keys attached.
desmar attached the following image(s):
Mathijs
#3 Posted : Saturday, August 27, 2016 12:01:51 PM(UTC)
Mathijs
I can do that, but how does that stop my panels getting mixed up?
desmar
#4 Posted : Saturday, August 27, 2016 12:34:02 PM(UTC)
desmar
Canada
Don't know, I don't have any X-keys to test with...
