Hardware Compatibility
multiple xkeys panels getting mixed up
I use xkeys panels with vmix. My main system runs Windows 7 and however I connect the xkeys panels, it does recognize which is which, so my left panel is not getting mixed up with my right panel.
Now I have set up another system to show a client it can also be the perfect AV switcher with integrated playout. This machine is running Windows 10. Today I did take my keypanels with me of the main system, so I had two connected. I did setup the shorcuts, checked that it all worked, and at a point I had to reboot the system. After the reboot, my keypanels were mixed up and I had to pick up the "midi channels" again for each key to get it working like it should.
I will of course experiment more after I've run my job tommorrow. Did anyone else run into this and does know a solution?
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
1) Export shortcuts from your Windows 7 system with x-Keys attached. 2) Import shortcuts to your Windows 10 system with x-Keys attached. desmar attached the following image(s):  Capture99PNG.PNG (24kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
I can do that, but how does that stop my panels getting mixed up?
Don't know, I don't have any X-keys to test with...
