PFBM
#1 Posted : Wednesday, August 10, 2016 6:11:59 AM(UTC)
PFBM
not working with hardware encoding streaming... again.... :(
FFMPEG.Exited
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video:audio=vMix Audio':
Duration: N/A, start: 58487.111000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (UYVY / 0x59565955), uyvy422, 1280x720, 25 tbr, 10000k tbn, 25 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 043868a0] TCP Buffer has been set to 4150272 bytes
[nvenc @ 04389240] >> dl_fn->cu_init(0) - failed with error code 0x3e7
Output #0, flv, to 'rtmp://www.*******.org:****/******/******':
Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, 25 fps
Metadata:
encoder : Lavc57.3.100 nvenc
Stream #0:1: Audio: aac, 0 channels, 128 kb/s
Metadata:
encoder : Lavc57.3.100 libfaac
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (nvenc))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (libfaac))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Cheers,
PFBM
#2 Posted : Wednesday, August 10, 2016 6:46:09 AM(UTC)
This error indicates a temporary problem with the Nvidia driver.
Restart your computer and make sure latest drivers are installed.
PFBM on 8/10/2016(UTC)
PFBM
#3 Posted : Wednesday, August 10, 2016 10:31:35 AM(UTC)
PFBM
restarted , updated ... same bug :(
NVIDIA System Information report created on: 08/09/2016 15:29:22
[Display]
Operating System: Windows 10 Pro, 64-bit
DirectX version: 12.0
GPU processor: GeForce GTX 960
Driver version: 368.81
Direct3D API version: 12
Direct3D feature level: 12_1
CUDA Cores: 1024
Core clock: 1177 MHz
Memory data rate: 7010 MHz
Memory interface: 128-bit
Memory bandwidth: 112.16 GB/s
Total available graphics memory: 10196 MB
Dedicated video memory: 2048 MB GDDR5
System video memory: 0 MB
Shared system memory: 8148 MB
Video BIOS version: 84.06.14.00.DB
IRQ: Not used
Bus: PCI Express x16 Gen2
Device Id: 10DE 1401 32011462
Part Number: G301 0000
[Components]
NvUpdtr.dll 2.11.4.0 NVIDIA Update Components
NvUpdt.dll 2.11.4.0 NVIDIA Update Components
NvGFTrayPluginr.dll 2.11.4.0 NVIDIA GeForce Experience
NvGFTrayPlugin.dll 2.11.4.0 NVIDIA GeForce Experience
nvui.dll 8.17.13.6881 NVIDIA User Experience Driver Component
nvxdsync.exe 8.17.13.6881 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.13.6881 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.13.6881 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.13.6881 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.13.6881 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.950.0 NVIDIA Control Panel
nvCplUI.exe 8.1.950.0 NVIDIA Control Panel
nvWSSR.dll 6.14.13.6881 NVIDIA Workstation Server
nvWSS.dll 6.14.13.6881 NVIDIA Workstation Server
nvViTvSR.dll 6.14.13.6881 NVIDIA Video Server
nvViTvS.dll 6.14.13.6881 NVIDIA Video Server
nvLicensingS.dll 6.14.13.6881 NVIDIA Licensing Server
NVSTVIEW.EXE 7.17.13.6881 NVIDIA 3D Vision Photo Viewer
NVSTTEST.EXE 7.17.13.6881 NVIDIA 3D Vision Test Application
NVSTRES.DLL 7.17.13.6881 NVIDIA 3D Vision Module
nvDispSR.dll 6.14.13.6881 NVIDIA Display Server
NVMCTRAY.DLL 8.17.13.6881 NVIDIA Media Center Library
nvDispS.dll 6.14.13.6881 NVIDIA Display Server
PhysX 09.16.0318 NVIDIA PhysX
NVCUDA.DLL 6.14.13.6881 NVIDIA CUDA 8.0.0 driver
nvGameSR.dll 6.14.13.6881 NVIDIA 3D Settings Server
nvGameS.dll 6.14.13.6881 NVIDIA 3D Settings Server
#4 Posted : Wednesday, August 10, 2016 11:02:04 AM(UTC)
Perhaps try reinstalling the driver. Error code 0x3e7 is CUDA code 999 which means CUDA_ERROR_UNKNOWN.
This means something is wrong with the driver somewhere as any application using NVENC would fail, not just vMix.
