Instant Replay Settings - Recording Format Options grayed out
I am confused about Instant Replay. What I add Instant Replay as an Input, the Instant Replay Input Settings window opens but the Recording Format options for resolution and frame rate are grayed out (see attached). What am I missing? - Tom sinc747 attached the following image(s):  ir settings2.PNG (33kb) downloaded 9 time(s).You cannot view/download attachments. Try to login or register.
Try specifying a new recording location.
 2 users thanked ask for this useful post.
Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
Or just empty the folder you're using before opening vMix, that also works :)
