BobR
#1 Posted : Sunday, August 7, 2016 8:54:12 AM(UTC)
BobR
I'm trying to use this capture device in vMix, without success. vMix sees the device but I can't seem to configure it as an input. I've tried every configuration listed but still no luck getting it setup as an input. I see a couple of posts where it seems to be working. Can someone suggest the proper configuration you are using with this device. I have a Sony DVCAM attached, using SVIDEO, and both LEDs are lit, on the USB-Live 2. I do get a picture using the supplied software that is provided with the device.
Any help will be appreciated.
Thanks,
Bob
kjones9999
#2 Posted: : Friday, August 12, 2016 12:58:30 PM(UTC)
kjones9999
Hi Bob. Svideo is not the default. have you changed that in the input settings?
BobR
#3 Posted : Friday, August 12, 2016 1:16:19 PM(UTC)
BobR
Thanks for the suggestion, I do have Svideo selected. I've been able to get the Live 2 device to see my camera and I can view the picture in Win10 but not using vMix.
