I'm trying to use this capture device in vMix, without success. vMix sees the device but I can't seem to configure it as an input. I've tried every configuration listed but still no luck getting it setup as an input. I see a couple of posts where it seems to be working. Can someone suggest the proper configuration you are using with this device. I have a Sony DVCAM attached, using SVIDEO, and both LEDs are lit, on the USB-Live 2. I do get a picture using the supplied software that is provided with the device.
Any help will be appreciated.
Thanks,
Bob
Hi Bob. Svideo is not the default. have you changed that in the input settings?
Thanks for the suggestion, I do have Svideo selected. I've been able to get the Live 2 device to see my camera and I can view the picture in Win10 but not using vMix.
