BETech
#1 Posted : Saturday, July 16, 2016 12:59:20 PM(UTC)
BETech
Using the same method or shortcut to add an input, ‘AddInput’, is there a way to change an Input source using a shortcut or API code?
The requirement is to change the Title file for a fixed Title’s Input via a Midi shortcut. The question was asked by another forum User last year, but only the manual procedure in the Settings dialogue was provided. http://forums.vmix.com/d....aspx?g=posts&t=5637
Digitalson
#2 Posted : Sunday, July 17, 2016 3:17:26 PM(UTC)
Digitalson
Groups: Guests
Do mean the ability to select a input without putting it in preview? I would love to have this for the app I am making ,for overlays ,instead of having 4 rows of every input I can have 1 with 4 dsk switches
#3 Posted : Sunday, July 17, 2016 10:56:58 PM(UTC)
Reloading title files during production is resource intensive and is not recommended.
Can you describe a scenario where this would be needed?
You can already setup Title Presets for a single template, so you can setup all the speakers during a production and switch between them
using the same template.
ask
#4 Posted : Monday, July 18, 2016 3:26:21 AM(UTC)
ask
What about offloading the titles to a second machine and then bring that in via an NDI input. With that number, and the dynamic nature you describe, it would seem to me that it would be a dedicated operator's job to manage. I essentially do a similar thing with NewBlue Titler, and would suspect that those using CasperCG are the same.
